Sonarr version (exact version): 20180303-03 (Synology Package Manager)
Mono version (if Sonarr is not running on Windows): 5.8.0.108-11
OS: Synology DSM 6.1
Unfortunately I can’t start Sonarr to enable debugging however the output I have from Synlogy is quite verbose and hopefully enough.
After using the Restart option in the GUI Sonarr won’t run anymore. Tried reboots and no go. I’m not that much of a Linux expert so I didn’t want to make a mess.
Logs say another copy is running but unable to access via browser, confirmed with telnet on port 8989
This is the first time i have used the restart button since an update came through in package manager for both Sonarr/Radarr.
The logs state as below
Fri Mar 16 06:58:17 NZDT 2018
Starting nzbdrone command env PATH=/usr/local/mono/bin:/volume1/@appstore/nzbdrone/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/syno/sbin:/usr/syno/bin:/usr/local/sbin:/usr/local/bin HOME=/volume1/@appstore/nzbdrone/var LD_LIBRARY_PATH=/volume1/@appstore/nzbdrone/lib /usr/local/mono/bin/mono /volume1/@appstore/nzbdrone/share/NzbDrone/NzbDrone.exe
[Info] Bootstrap: Starting Sonarr - /volume1/@appstore/nzbdrone/share/NzbDrone/NzbDrone.exe - Version 2.0.0.5153
[Info] SingleInstancePolicy: 1 instance(s) of Sonarr are running
[Warn] SingleInstancePolicy: Another instance of Sonarr is already running.
[Info] Bootstrap: Application is being terminated. Reason : Another instance is already running
Any help greatly appreciated.
Cheers
SachmoNZ
