Sonarr Synology Not Finding Shows with a Hyphen
Im running version 20150731-8 on my synoogy and shows with a hyphen are not being found. Thought it was a one off when I added The X-files. Just added Brooklyn Nine-Nine and its not being found either.
My indexer is oznzb, I added 5000 to its categories just in case. I can find the show when using a hyphen by manually searching the site. I even installed sickbeard to see if it would find it, and it did.
I don’t know if I should install a different version of sonarr or if theres something simple I can change to make it work
Thats not a Sonarr version number, thats the number from the Synology package, if Sonarr hasn’t been updated since it was installed definitely update. Dashes shoud be removed when searching, but most indexers are searched using IDs, which makes matching better, ((debug logs)) of a search will confirm which Sonarr is using for OZnzb.
