Sonarr version: 20180303-13
Mono version: 5.8.0.108-11
Synology: DSM 6.0.3-8754 Update 8
Debug logs: I understood that I can find the logs under: /volume1/@appstore/nzbdrone/var/.config/NzbDrone but I cannot access these files.
**Description of issue: I used to use Sonarr, but after updates of DSM I could not get it started anymore. If I look at the package center the status states: Stopped, if I try to run it (action --> run) nothing happens. Hopefully somebody can help me out, since I would love to get this running again!
Just want to say I’m having the same problem. Hope someone knows what’s going on.
Anyone who is able to help out?
Do the Sonarr log files show it starting?
If not the issue is likely with the package or mono, you could try to run it manually to rule out mono mono --debug /path/to/NzbDrone.exe.
This is what worked for me. Hope it helps.
https://forum.synology.com/enu/viewtopic.php?f=190&t=120206&p=457254#p457254
