Sonarr version (exact version): Latest Stable Version installed tonight
Mono version (if Sonarr is not running on Windows): Mono JIT compiler version 5.2.0.215 (d15-3/da80840 Thu Jul 20 16:43:07 EDT 2017)
OS: OSX 10.13.3
Debug logs: https://hastebin.com/oxuhumirat.rb
Sonarr recently quit loading and does the 4 loading dots of doom…
I have deleted and resinstalled several times, did the back up and restore process, used chrome incognito and etc and can’t figure out why it won’t load.
The linked logs are empty, It’d be best to enable trace logging (you’ll need to do that through finder) and restart Sonarr then try to load it.
How do I enable the trace logs in finder?
edit- I see your link now and have them enabled i have tried to start it twice and going to let it run some before i post the logs
