Sonarr version (exact version): 4.0.1.929
OS: Unraid docker Linuxserver
The above screenshot shows a release rejected marker for ‘DVD’
Here’s my quality profile with DVD showing:
Sonarr gets its average runtime from THETVDB:
https://thetvdb.com/series/naruto-shippuden
Average runtime is 23min
I have searched for Season 1. Within Sonarr, Season 1 has 32 episodes:
32*23min= 736minutes Season 1 runtime, not 11500min as Sonarr has calculated
multiplying by 5mb: Around 3.7Gb should be the minimum and therefore this release shouldn’t be rejected.
What is the issue? Even if I double it, for e.g. if sonarr thinks it’s double episodes or somerthing, double would be 7.4Gb. I still won’t be able to download the file because it’s 10.1Gb.
10.1Gb/736 minutes is 13.7mb per minute and therefore should fall within my range.
You can reproduce these steps yourself by adding the show, setting the series type to standard episode format and searching Season 1 packs, no need for logs.
