Sonarr should place episodes in folders for example the episode 8 should be in a folder named 08. And if i put them manually and rename the files sonarr put them out again
Like I said on the issue you opened on github, you can do that.
Either add {episode:00}\ or {episode:00}/ (depending on if you’re running Sonarr on Windows or another OS respectively) to the episode naming formats.
Please stop opening other threads and github issues. I’ve seen your post here, but I need to look into this issue further and open an issue as required.
And please don’t add replies with only mentions (to unrelated users at that).
