Sonarr version (3.0.0.298):
Mono version (5.14.0.177):
**OSQNAP 4.3.6.0805:
Hello,
I am hitting a little issue.
Here is the setup
QNAP running Sonarr
Ubuntu VM running plex_server “accessing library through mounted network share” "works perfectly
Seedbox rutorrent “feralhosting”
I have mounted the complete folder from my seedbox via ssHFs to: /mnt/complete
Within the sonarr settings under download clients
Remote Path Mappings
remote patch /mnt/complete
local path: /some_local_path where I usually used resilient to sync from seedbox localy to manually move the media in its proper folders
no special arguments used for mounting through sshHFs
hostname.feralhosting.com:/media/XXX/YYY/private/rtorrent/data/complete
is rutorrent puts the files and that is mounted
Import failed, path does not exist or is not accessible by Sonarr
I am guessing it may something to do with permissions
thoughts?
