Sonarr version (2.0.0.4949):
Mono version (5.0.1.1):
OS: Ubuntu 16.04
(https://zerobin.net/?e02baf4eeba6cf6e#San2j+MqpO9vnjhdLqsKuze7PBVBA/vnWqboLtTXG98=):
Description of issue: I have recently installed Sonarr and have not had luck getting it to run more than 24 hours without it “crashing” into a locked up state with a white screen. If I stop the service the white goes away and the webserver is completely gone. Once I restart everything it comes back up just fine, works properly, and has no issues. I have the permissions for it set to myusername:nogroup, a systemd unit script set to start it up on boot, which executes flawlessly.
I keep thinking my permissions are messed up and that causes the table lock in the logs, but if the permissions were mis-configured, it wouldn’t work at all.
I am at a loss, I posted a log with the table errors. Hopefully someone else has experienced this. I have disabled my service scripts and have started Sonarr from the command prompt to try and isolate the issue.
