Sonarr rejecting Occupation Double Panama releases due to TVDB alias conflict
Sonarr version (exact version) : 4.0.20.3014
OS : Linux
Hello,
I’m experiencing an issue with Sonarr when searching for episodes of Occupation Double Panama (2026) .
The series has its own TVDB entry:
  • Occupation Double Panama – TVDB ID: 468179
  • Occupation Double – TVDB ID: 274765
When searching for episodes, Sonarr rejects the releases with the following error:
Occupation Double Panama matches an alias for series with TVDB ID: 274765
The releases are available on my indexer (C411) and are correctly named using Season 10 numbering.
Example:
Occupation.Double.Panama.S10E62.AD.VFQ.1080p.WEB.AC3.5.1.H264-MTLQC
The releases use S10E01, S10E02, S10E03, etc., while the main Occupation Double TVDB entry lists the same 2026 episodes under Season 20.
Prowlarr successfully finds the releases, and the connection between Prowlarr and Sonarr is working correctly. However, Sonarr rejects these releases because of the TVDB alias conflict.
Other series work correctly with my current Sonarr configuration.
Could you please investigate the alias conflict and scene mapping for these two TVDB entries?
I would like Sonarr to recognize Occupation Double Panama (TVDB ID 468179) and accept releases numbered S10E01, S10E02, etc.
Thank you for your help!
This looks like Sonarr resolving the parsed title through TVDB aliases before considering the exact series title. Since “Occupation Double Panama” is an alias on the parent entry (274765), Sonarr maps the release there and rejects it rather than accepting 468179. If you can edit TVDB, remove that alias from the parent and refresh both series; otherwise this likely needs a Sonarr-side alias-conflict fix, with manual import as a workaround.
