Sonarr Randomly Stops Running
http://pastebin.com/36wS5x1s
Ubuntu 14.04 x64
Version 2.0.0.3154
Mono Version 4.0.1 (tarball Tue May 12 15:39:23 UTC 2015)
Fresh server, fresh install of sonarr, no backups. I had the 3.10 mono installed but then i read that it was buggy, so i upgraded and i was worried that 4.01 wasn’t supported but then i found a thread here saying it actually was.
I’ve gone from every 15 minutes sonarr needing to be started (3.10) to every hour or so with 4.01.
I am presuming it is mono… but not certain.
15-5-27 22:27:54.1|Fatal|GlobalExceptionHandlers|EPIC FAIL: Object reference not set to an instance of an object
have you looked at the sticky?
https://forums.sonarr.tv/t/native-mono-crashes/?source_topic_id=5770
I am not on a VM. But i will take another look.
I think its not just VM’s from what ive seen talked about in the irc channel
