Sonarr on Synology Rackstation
I’m trying to load Sonarr on my RS3617RPxs but no matter what I try and can’t get the package to show up in Package center. I have the Synocommunity repo loaded and all publishers are trusted and checked the box for Beta’s. I also have a DS1815+ running the exact same version of DSM 6.1.3-15152 and it shows up there just fine. What am I missing? Is there something about this box that would not allow it to install? AFAIK there shouldn’t be any difference as it’s an x86 platform.
I’m not aware of any reason it won’t show up, are there other packages that don’t show up?
The Synology package is maintained by a 3rd party and you may get better visibility on the syno forums or the syno community repo.
On the one hand it says in the SynoCommunity FAQ they don’t support DSM 6.1, on the other hand you say it’s there for your 1815+ and the architecture of your RS3617RPxs (bromolow) is listed for the sonarr package.
I don’t know. Maybe 6.1 support is still flaky…
Yeah there are a number of them that do show up, but there are several missing. Sonarr and Transmission are what I wanted but of course both of them are missing.
I had the same problem on my Xpenology Home Build but I added the following repo:
https://www.cphub.net and checked the Beta box in settings now I get an unbelievable amount packages.
