Sonarr version (exact version): 2.0.0.4326
Mono version (if Sonarr is not running on Windows): 4.4.2
OS: Application is running on a Seedbox
((Debug logs)): https://www.dropbox.com/s/eqq3gowvue4rdeg/Seedbox%20Log%2020160921.rtf?dl=0
Description of issue: Ok here goes. I have used Sonarr on my home network for a while and now I started to use a seedbox and have it configured on there now. Sonarr connection tests work to Transmission and files are downloaded to the seedbox itself, the issue I have is that once it is downloaded I have set sonarr to extract the files to a given location. I set sonarr to create empty series folders which it has done but when the files are downloaded the files are not extracted there.
Any help would be greatly appreciated. The private torrent tracker I am using doesn’t support searching I will not have full debug logs until it pick new series that run tomorrow.
Thanks.
