Mono version (if Sonarr is not running on Windows): 5.18.1.0
OS: QuickBox v1.2.3
Description of issue: I’ve just moved to a new dedicated seedbox that comes with sonarr, but I’m stumped on how to get it to see my local drive on my pc with remote path mappings. My current setup is sonarr on my pc sending torrents to the seedbox for download, and then btsync to sync completed downloads back to local pc.
You’d need to map it in some way, you’re probably better off running Sonarr locally and then importing locally.
I would keep using it locally, but I want to use autodl-curl-sonarr. If it’s possible to use the autodl script on the seedbox and use sonarr locally, that’ll be perfect, but I don’t know how to do it lol.
EDIT: used a reverse proxy and got it to work.
