Hi there,
I’ve been using Sonarr for nearly a year on a NAS (before on a Synology DS415Play, but now on a QNAP TS453 Mini). So far so good. I am very pleased with the app. It works perfecly !
So far I used Sonarr exclusively with NZB. But I wanted to push it further and use Torrent as backup.
For that, I wanted to use a remote seedbox (seedboxes.cc) that will handle all the torrent downloading. When the torrent is completed, I want to grab it directly from the remote server.
I tried to configure the download client in Sonarr : I chose Deluge and put all info according to seedboxes’ website.
The link works perfectly : I can send to the seedbox a download, track the activity, remove torrent+file uppon request, etc.
Unfortunately, I am not able to retrieve the downloaded file to my NAS. After some researches, I seems that I must specify a remote path mapping. But I have no precise idea of how I have to configure that
So could anyone help me with the remote path mapping configuration, especially :
Host: My seedbox ip ? should I write it so : user:password@ip:port ?
Remote Path: Path where the seedbox put the file ?
Local Path: local NAS path where it should copy the file ?
Should I mount the remote drive on my NAS ? So far I was able to mount it through FTP…
Thanks in advance and sorry for the confusion !
note : On my seebox I can choose to use deluge/transmission/rutorrent. In case one works better than another
