Mono version (if Sonarr is not running on Windows): 6.12.0.200
OS: Unraid Version: 6.12.4
Sonarr is not using the path set in the Remote Path Mappings. The Remote Path is a folder in a remote seedbox, which is synched to the local path accessible by Sonarr.
The Remote Path is the following: /home/[USERACCOUNT]/downloads/rtorrent/completed/
[USERACCOUNT] is the actual username issued by the seedbox provider, removed for privacy.
In the Events the following message appears:
Import failed, path does not exist or is not accessible by Sonarr: /home/(removed)/downloads/rtorrent/Barry.S01E01.WEB.h264-TBS[ettv]. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
It replaces the actual user name with (removed).
It is not a permission issue. When I trigger a Manual Import with the path set in Remote Path Mappings Sonarr can correctly import the file and remove it from the download directory.
