Sonarr version (exact version): 2.0.0.4326 OS: Windows 7 ((Debug logs)): (Make sure debug logging is enabled in settings and post the full log to hastebin/pastebin/dropbox/google drive or something similar, do not post them directly here) Description of issue:
My Sonarr installation is not seeing when files get done downloading all of a sudden. When I go to Activity | Queue, it shows 18 files downloading but they all say 00:00:00 for Time Left. If I open up the series, all of the shows show a full purple bar and say Episode is Downloading - 100%. When I look in uTorrent it has moved the torrent to the Completed section and shows it downloaded successfully.
Any idea what might be causing this to not work all of a sudden? I just turned on Debug Logging and will let it spin for a bit and can then post the logs if needed.
Just did the hover thing and saw this as a sample:
Downloaded Chicago.Med.S02E02.720p.HDTV.x264-FLEET[rarbg]
[/Chicago.Med.S02E02.720p.HDTV.x264-FLEET[rarbg]] is not a valid local path. You may need a Remote Path Mapping.
All of them have the error about the: Not a valid local path.
Nothing has changed on the computer and it’s saving to the internal hard drive and not to a server or anything.
It looks like I’m using uTorrent 2.2. I know this has come up before and that’s an old version and I upgraded it but it somehow keeps reverting back every once in a while for unknown reason. Argh. no idea wtf is going on.
If I put the current version back on will that hopefully go back and figure out what’s where and move things where they need to go?
