Added Series to sonarr, and it added the right series, but it wont see or pickup episodes, when i manually search for the nzb outside of sonarr i find it easily.
this is the name of the nzb when i search for it outside of sonarr.
( [Our World 2007 S2020E01 Colombia The New Cocaine War 720p IP WEB-DL AAC2 0 H 264-RTN]
Check the categories that Sonarr is using for those indexers, your six indexers returned a single result (without debug logs we can’t even see what it was).
They’re not the same on NZB Finder at least, which categorizes those releases as Movies: WEBDL, which I believe has a category ID of 2080, but you’ve only added 2040.
This is an indexer problem though, those releases should be in TV, not movies and other indexers do that.
You are a saint i swear. that fixed it and it picked it up, but for some reason i only saw 2040 when i hover over the link, how did you see the id was 2080 ?
because im having a simular problem now with prev episodes.
nzbplanet shows this - Our World 2007 S2019E31 Europes Greenest Town 720p iP WEB-DL AAC2 0 H 264-RTN
but sonarr does not see that one, nzbplanet suggest it is TV > HD - 5040
so i added 5040 but it wont see it inside that category.
