Sonarr version (exact version): 3.0.8.1507
OS: Windows 10 Pro 64 bit
Debug logs: https://gist.github.com/sdw1187/bc09519713f347a0f890d4fed56fe371
Description of issue: Sonnarr is not returning results when searching for shows. Automatic search, Manual search, Update all, RSS Sync everything I attempt to do to search for new shows suddenly stopped working sometime in the early morning hours today (6/2/2022). The search appears to run, no error messages, and just returns no results.
This issues started with Sonarr 2.0.x.xxxx and I upgraded during the troubleshooting. Still seeing the same results. I’m running out of ideas short of nuking the database and just starting over.
Troubleshooting steps I’ve taken so far:
- Confirmed internet connection gets out to the internet
- Turned off VPN, was still able to reproduce the issue.
- Restarted the service
- Rebooted the box
- Confirmed my indexer, NZBgeek, had the specific content I was looking for which was Obi-Wan Kenobi S1E1.
- Confirmed by NZBgeek account was still active
- Updated the API Key in Sonnar and tested
- Confirmed the same API Key is working in Radarr, and it is returning results on Radarr!
- Updated Sonarr to version 3.0.8.1507, and rebooted the box - still same results
- Turn logging on to Debug, reproduced the issue.
I’m out of ideas. Anyone got a suggestion?
Here is the bit where I’m searching for the episode:
2022-06-02 16:50:35.6|Debug|ReleaseSearchService|Total of 0 reports were found for [Obi-Wan Kenobi : S01E01] from 2 indexers
2022-06-02 16:50:35.6|Debug|ReleaseSearchService|Setting last search time to: 6/2/2022 9:50:35 PM
2022-06-02 16:50:35.6|Info|DownloadDecisionMaker|No results found
2022-06-02 16:50:35.6|Debug|Api|[GET] /api/v3/release?episodeId=9404: 200.OK (61 ms)
2022-06-02 16:50:42.8|Debug|Api|[GET] /api/v3/health: 200.OK (0 ms)
2022-06-02 16:50:42.8|Debug|Api|[GET] /api/v3/system/status: 200.OK (4 ms)
2022-06-02 16:50:43.4|Debug|Api|[GET] /api/v3/diskspace: 200.OK (585 ms)
2022-06-02 16:50:44.7|Debug|Api|[GET] /api/v3/command: 200.OK (1 ms)
2022-06-02 16:50:45.5|Debug|Api|[GET] /api/v3/qualitydefinition: 200.OK (1 ms)
2022-06-02 16:51:10.1|Debug|Api|[PUT] /api/v3/qualityDefinition/update: 202.Accepted (8 ms)
2022-06-02 16:51:39.7|Debug|Api|[GET] /api/v3/episode?seriesId=114: 200.OK (2 ms)
2022-06-02 16:51:39.7|Debug|Api|[GET] /api/v3/queue/details?seriesId=114: 200.OK (1 ms)
2022-06-02 16:51:39.7|Debug|Api|[GET] /api/v3/episodeFile?seriesId=114: 200.OK (6 ms)
2022-06-02 16:51:44.7|Debug|SabnzbdProxy|Url: http://localhost:8080/api?mode=queue&start=0&limit=0&apikey=(removed)&output=json
2022-06-02 16:51:46.7|Debug|SabnzbdProxy|Url: http://localhost:8080/api?mode=history&start=0&limit=60&category=tv&apikey=(removed)&output=json
2022-06-02 16:51:46.9|Debug|Api|[GET] /api/v3/queue/details?seriesId=114: 200.OK (1 ms)
2022-06-02 16:51:46.9|Debug|Api|[GET] /api/v3/command: 200.OK (0 ms)
2022-06-02 16:51:47.1|Debug|Api|[GET] /api/v3/queue/details?seriesId=114: 200.OK (2 ms)
2022-06-02 16:51:47.1|Debug|Api|[GET] /api/v3/command: 200.OK (3 ms)
2022-06-02 16:51:51.0|Info|ReleaseSearchService|Searching indexers for [Obi-Wan Kenobi : S01E01]. 2 active indexers
2022-06-02 16:51:51.0|Debug|ReleaseSearchService|Total of 0 reports were found for [Obi-Wan Kenobi : S01E01] from 2 indexers
2022-06-02 16:51:51.0|Debug|ReleaseSearchService|Setting last search time to: 6/2/2022 9:51:51 PM
2022-06-02 16:51:51.0|Info|DownloadDecisionMaker|No results found
2022-06-02 16:51:51.0|Debug|Api|[GET] /api/v3/release?episodeId=9404: 200.OK (113 ms)
2022-06-02 16:51:56.9|Debug|Api|[GET] /api/v3/history?pageSize=1000&page=1&sortKey=date&sortDirection=descending&episodeId=9404: 200.OK (158 ms)
2022-06-02 16:52:03.3|Debug|Api|[POST] /api/v3/command: 201.Created (5 ms)
2022-06-02 16:52:03.4|Info|ReleaseSearchService|Searching indexers for [Obi-Wan Kenobi : S01E01]. 2 active indexers
2022-06-02 16:52:03.4|Debug|ReleaseSearchService|Total of 0 reports were found for [Obi-Wan Kenobi : S01E01] from 2 indexers
2022-06-02 16:52:03.4|Debug|ReleaseSearchService|Setting last search time to: 6/2/2022 9:52:03 PM
2022-06-02 16:52:03.4|Info|DownloadDecisionMaker|No results found
2022-06-02 16:52:03.4|Info|EpisodeSearchService|Episode search completed. 0 reports downloaded.
2022-06-02 16:52:03.4|Debug|Api|[GET] /api/v3/command: 200.OK (1 ms)
2022-06-02 16:52:07.6|Debug|Api|[POST] /api/v3/command: 201.Created (7 ms)
2022-06-02 16:52:07.6|Info|ReleaseSearchService|Searching indexers for [Obi-Wan Kenobi : S01E01]. 2 active indexers
2022-06-02 16:52:07.6|Debug|ReleaseSearchService|Total of 0 reports were found for [Obi-Wan Kenobi : S01E01] from 2 indexers
2022-06-02 16:52:07.6|Debug|ReleaseSearchService|Setting last search time to: 6/2/2022 9:52:07 PM
2022-06-02 16:52:07.7|Info|DownloadDecisionMaker|No results found
2022-06-02 16:52:07.7|Info|EpisodeSearchService|Episode search completed. 0 reports downloaded.
2022-06-02 16:52:07.7|Debug|Api|[GET] /api/v3/command: 200.OK (0 ms)
2022-06-02 16:52:09.5|Info|ReleaseSearchService|Searching indexers for [Obi-Wan Kenobi : S01E01]. 2 active indexers
2022-06-02 16:52:09.6|Debug|ReleaseSearchService|Total of 0 reports were found for [Obi-Wan Kenobi : S01E01] from 2 indexers
2022-06-02 16:52:09.6|Debug|ReleaseSearchService|Setting last search time to: 6/2/2022 9:52:09 PM
2022-06-02 16:52:09.6|Info|DownloadDecisionMaker|No results found
2022-06-02 16:52:09.6|Debug|Api|[GET] /api/v3/release?episodeId=9404: 200.OK (67 ms)
2022-06-02 16:53:10.7|Debug|Api|[GET] /api/v3/health: 200.OK (2 ms)
2022-06-02 16:53:10.8|Debug|Api|[GET] /api/v3/system/status: 200.OK (71 ms)
2022-06-02 16:53:11.2|Debug|Api|[GET] /api/v3/diskspace: 200.OK (413 ms)
2022-06-02 16:53:14.4|Debug|Api|[GET] /api/v3/log/file: 200.OK (2 ms)
2022-06-02 16:53:14.7|Debug|SabnzbdProxy|Url: http://localhost:8080/api?mode=queue&start=0&limit=0&apikey=(removed)&output=json
2022-06-02 16:53:14.7|Debug|SabnzbdProxy|Url: http://localhost:8080/api?mode=history&start=0&limit=60&category=tv&apikey=(removed)&output=json
2022-06-02 16:53:14.8|Debug|Api|[GET] /api/v3/command: 200.OK (0 ms)
2022-06-02 16:53:15.1|Debug|Api|[GET] /api/v3/command: 200.OK (6 ms)
