Sc1
December 2, 2018, 12:17pm
1
Sonarr is not importing subtitles that are in folders especially that doesn’t have the same name as the episode file. For instance Rarbg usually have a subtitle file with 2 subtitle and I would like the one named 3_eng.srt
is this possible?
Completed\TV\Series.s02e04.WEBRip.x264-RlsGrp\Series.s02e04.WEBRip.x264-RlsGrp.mp4
Completed\TV\Series.s02e04.WEBRip.x264-RlsGrp\RlsGrp.txt
Completed\TV\Series.s02e04.WEBRip.x264-RlsGrp\Subs\2_Eng.srt
Completed\TV\Series.s02e04.WEBRip.x264-RlsGrp\Subs\3_Eng.srt
Sc1
December 2, 2018, 12:26pm
2
I would import them manually if I could retrieve the subtitle but it vanishes
TRaSH
December 2, 2018, 3:17pm
3
Try the following
Settings > Media Management
Sc1
December 2, 2018, 4:13pm
4
Already did, it works only when the subtitles are not in a file
TRaSH
December 2, 2018, 4:35pm
5
Do you use torrents or usenet to download the rarbg files ?
(Yes I know rarbg is a tracker but there files are also found on usenet)
TRaSH
December 2, 2018, 5:06pm
7
Okay that’s a shame if it was usenet you could use in nzbget flatten folder.
system
Closed
January 31, 2019, 5:06pm
8
