Sonarr version (exact version): 2.0.0.4855 Mono version (if Sonarr is not running on Windows): OS: Win 10 x64 (latest updates) ((Debug logs)): https://pastebin.com/eD6jDcJr (warnings only) (Make sure debug logging is enabled in settings and post the full log to hastebin/pastebin/dropbox/google drive or something similar, do not post them directly here) Description of issue:
My setup was working flawlessly while I was running it on Windows Server 2012R2 (after some messing around with things).
Decided to go back to Win10x64 as I no longer required a server version of Windows.
Did a fresh install of Windows, and moved over my uTorrent folder from my server HDD, installed sonarr and jacket. I believe I restored my Sonarr and re-pointed paths as required.
I am also running the latest version of Jackett, only used for indexing PirateBay and TorrentDay (private).
Manual searches are working fine.
Clicking Wanted -> selecting latest shows -> and searching selected also works.
I cannot think of why this is happening, it looks like it is having RSS issues, but it is extremely coincidental that it happens as soon as I moved it back to Windows 10…
Any help is appreciated, thank you.
You’ll need to check ((debug logs)) which is in the log file, not the log table and see if Sonarr even saw the releases you were looking for. ThePirateBay rss sync didn't cover the period between 7/10/2017 11:11:10 AM and 7/10/2017 11:21:41 AM UTC generally indicates Sonarr didn’t execute a RSS Sync for some time and failed to page back far enough to find all the releases.
If RSS Sync is running every 10 minutes and there are gap then it might be possible for Jackett to fetch more items from the indexer so that doesn’t happen, if it can’t fetch more or allow Sonarr to page the results then there is always going to be a chance that something is missed.
@markus101
I am just confused as I never had any issues like this.
I did a fresh install of win10, installed sonarr and jackett, copied some of my configs over and reconfigured where required.
to my knowledge, my RSS sync was always 10 mins.
Could there be a setting I am missing?
Any idea what I would be looking for in my debug logs?
Thanks
@markus101
thank you for answering so quickly.
Like anything Windows Based… sometimes you just need to remove something and re-add it…
I removed all my indexers from Sonarr, restart the service, re-added the indexers as torznab with jackett, restarted service again, and when the RSS Sync ran, it grabbed the shows.
