Sonarr version 2.0.0.5338 - Aug 14 2019
I’ve the lastest Sonarr version running on Docker / DSM, for over a year now, and everything worked fine until now.
Problem is, for no apparent reason Sonarr stopped grabbing my downloaded episodes from Transmission (they are idle at 100% with status “seeding complete”, although sending them from Sonarr to Transmission (manually or automatically) is no problem at all.
I enabled trace logging and downloaded suits s09e05, logs here:
Can you please help? I really do not understand what is the issue, I’ve changed no configurations or paths at all.
edit: I don’t remember the previous behaviour, but I see that on the downloads folder (my default por transmission) i see the download tv show folder empty, but it seems to be on Incomplete. So if go to Sonarr i can’t manual import because it says that there is no video files on the folder.
So perhaps the issue is that transmission for some reason is not moving the video file from the /downloads/incomplete/nameXXXX to /donwloads/nameXXXX ?
Part of my transmission (on docker) configuration:
“download-dir”: “/downloads”,
“download-queue-enabled”: true,
“download-queue-size”: 5,
“encryption”: 1,
“idle-seeding-limit”: 1,
“idle-seeding-limit-enabled”: true,
“incomplete-dir”: “/downloads/incomplete”,
“incomplete-dir-enabled”: true,
“lpd-enabled”: false,
