Sonarr version (exact version): 2.0.0.5252 Mono version (if Sonarr is not running on Windows): OS: Windows 10 64-bit Debug logs: https://drive.google.com/open?id=1tJjv5LgOV730hBOFgknnvdCK4Gw68upO Description of issue:
Show - Bachelorette Australia (alias recently added for “Bachelorette AU” through spreadsheet process). No episoded found through Sonarr. Episodes are found through manual Jackett search.
Most recent episode found through manual Jackett search:
Search used: “bachelorette au s04e05”
Markus,
Yes. The alias does show properly on the series details page.
One thing I did notice was that the series previously had an alias of “The Bachelorette Australia”. Which is the same as the proper title. Not sure why that would be. It has since been changed to “The Bachelorette AU” (after my spreadsheet submission) but is still not been finding any episodes. As you noted, Sonarr does not seem to be doing any search on the alias name.
Thank you.
Another piece of information is that the show “Bachelor Australia” is setup exactly as this one with and alias of “Bachelor AU” and that one works fine.
Found the issue, there was an invisible space in the alias that caused it to be filtered out before the search executed. Refresh the series in 20 minutes or later and it should be good.
