Sonarr Not Detecting Torrent(Deluge) Completion
Hi. I currently have Sonarr set up on a headless Ubuntu 14.04 Server.
I have it using Deluge as the download client.
It worked for a while to download and detect download statuses. But now it no longer is able to detect the status of the torrent. It does show up in deluge and it downloads. Sonarr just isn’t detecting when it is completed.
Basically all downloads stay in the grabbed state - No Longer get processed and make it to imported state.
It was setup to download -> Create hardlink in destination folder.
Possible the same issue as here:
I am seeing the same thing here, just downloaded 10 episodes of the same series and all have finished however sonarr only sees one as being finished and the completed files are still in my completed folder but have not moved over to their designated series path. Some shows I have done during the same time are completing and moving fine.
Please create a new thread next time.
If you’re still having issues make sure they have the correct label set and create a new thread with trace logs posted to hastebin, showing the failing import.
