I have enabled Debug logs, removed the episode, readded the episode and then taken this from the sonarr.txt in the logs section.
If this isnt what you are looking for just let me know where to find these debug logs
Thanks.
17-1-9 11:44:21.5|Warn|ImportApprovedEpisodes|Couldn't import episode B:\tv-sonarr\Sherlock.S04E02.The.Lying.Detective.1080p.AMZN.WEBRip.DD5.1.x264-CasStudio[rartv]\Sherlock.S04E02.The.Lying.Detective.1080p.AMZN.WEBRip.DD5.1.x264-CasStudio.mkv
[v2.0.0.4472] System.IO.DirectoryNotFoundException: Root folder '\\SIRIUS-A\SIRIUS_TV1\Ripped TV Shows\' was not found.
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.EnsureEpisodeFolder(EpisodeFile episodeFile, Series series, Int32 seasonNumber, String filePath) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:line 160
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.CopyEpisodeFile(EpisodeFile episodeFile, LocalEpisode localEpisode) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:line 88
at NzbDrone.Core.MediaFiles.UpgradeMediaFileService.UpgradeEpisodeFile(EpisodeFile episodeFile, LocalEpisode localEpisode, Boolean copyOnly) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\UpgradeMediaFileService.cs:line 60
at NzbDrone.Core.MediaFiles.EpisodeImport.ImportApprovedEpisodes.Import(List`1 decisions, Boolean newDownload, DownloadClientItem downloadClientItem, ImportMode importMode) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeImport\ImportApprovedEpisodes.cs:line 103
