OS: Ubuntu 22.04.2 LTS (via Docker container)
Debug logs: TBP
Description of issue: Sonarr empties queue, yet the remote Transmission instance retains torrent files.
- Transmission is remote and referenced via https.
- Category defined as
sonarr-category
- Items are transferred via Syncthing to local container (details in pastebin)
- Requests/Imports are fine, just lacking deletion
https://pastebin.com/FBK7FtAc
I’ve tried quite a few areas of troubleshooting, none have offered desired results:
- adjusted seed ratio higher/lower
- removed/replaced category
- used socks5 proxy/http proxy
- monitored full trace of several torrent requests
- scoured general search, reddit, this forum (some mentions on similiar issues but nothing conclusive)
It’s interesting my configuration (other than staying current w/sonarr releases) hasn’t changed for nearly a year, using the same remote service. This is the first time I’ve seen this issue. The really ugly side of this is it’s part of a mostly automated system where requests queue up. There are periods of heavy processing which, without successful deletions, I end up with a significant amount of backlog data.
One thing which has been getting my attention is the consistency of "isFinished": false
at every single HttpClient Response. I’d like to know if that is single root cause or potentially amongst root cause of this issue. More detail:
https://pastebin.com/0qwWFBNz
I’d be happy to provide debug/trace logging but would prefer to know what to look for beforehand.
