Sonarr version (exact version): 4.0.4.1491
OS: Synology NAS
Hi,
I am new to Sonarr, but have an extensive TV library on my Synology NAS. I use it to run a Plex media server.
Sonarr v4 and Prowlarr are working together and are successfully accessing and downloading media from TorrentDay. Full permission to access read/write my root director has been given to Sonarr. However, even though I have imported my root directory, volume1/video/TV, into Sonarr, it does not automatically monitor the library even though it complies with standard folder and file naming protocols as far as I know. There are 219 unmapped folders! I discovered this problem when I manually added a handful of TV shows to update automatically. Sonarr has tried to download every season and episode from years back, seemingly unaware that I have all but the most recent episodes already!! TD are not happy! Oddly, when I look at monitored series the system is aware of teh correct location of the TV show and all its seasons, e.g., /volume1/Video/TV/Chicago Med Could it be that the system is monitoring some folders, but not 219 others. Why would that be? I do try to stick to standard folder and episode naming and structure protocol.
I will provide log files if necessary, but this must be a common problem with an easy solution, e.g. a configuration step I missed. I This morning I have put log into debug mode.
Thank you, if you can help.
