Sonarr version (exact version): 2.0.0.5322
OS: Open Media Vaule
Description of issue: When I add a new show to Sonarr or if I initiate a task Sonarr will only post the initial notification (not sure on the correct term but it is the little piece of information found to the bottom right of Sonarr), if i manually refresh the page the information will change but otherwise will stay stuck on the first notification. When I update library or search for a show manually it will spin continually and only stops when if I refresh it maually
Logs here:
https://drive.google.com/open?id=1Lsv4-vMBTb5DUy68GxViEd438tFqFRDO
