Sonarr not adding to downloads
Sonarr version (exact version):2.0.0.5301
Mono version (if Sonarr is not running on Windows):5.18.0.240
OS: Ubuntu 18.04
https://pastebin.com/mk45yPvz
So if i understand the debug logs correctly. It appears to accept certain releases but they aren`t actually being added to the download client. I do have a tag set to filter for releases containing golumpa however the logs seem to indicate that this is working fine. I have tested sonarrs connection to the download client (qbittorrent) and it appears to work fine. Can anyone shed some light on these logs?
I see an accepted release but the logs cutoff before it gets to the point where it’d try to grab the torrent and send it to the download client.
https://beppp.club/sonarr.debug.txt
https://beppp.club/sonarr.debug.0.txt
Here are the log files.
they`re too long to fit in a pastebin
Looks like Sonarr is would be grabbing things, but nyaa is getting disabled after returning results, but before it’s able to gran them:
19-3-3 19:46:14.7|Debug|DownloadDecisionMaker|Release rejected for the following reasons: [Permanent] Does not contain one of the required terms: golumpa, [Permanent] Not enough seeders: 0. Minimum seeders: 1, [Temporary] Indexer Nyaaa is blocked till 3/3/2019 7:51:13 PM due to failures, cannot grab release.
You should be able to use Nyaa directly with Sonarr instead of through Jackett, which may be better.
When I try to add it as indexer without jackett i get THE error indexer responded with HTML content. What url should I be using?
I figured it out but it seems to have the exact same problem. It gets disabled whenever I trigger a search
ok now it appears to not be disabled but it is still not grabbing episodes. Searching through the logs for the word bug doesnt do anything. Logs are hosted same as before
Clicking search on single episodes seems to work however
v2.0.0.5301] System.ArgumentOutOfRangeException: Can not search for Black Clover - S01E73 it does not have an absolute episode number
Parameter name: AbsoluteEpisodeNumber
Searching for an anime Season containing an episode without an absolute episode number will not work and will not grab anything. and it should pop up a quick flag saying “Search Failed” (Drives me nuts with specials). (Yes, I realize that it is episode 73 - I also realize that it isn’t scheduled to air until tomorrow), Refresh the series and update scene mapping. then expand the season and see if episode 73 still has the warning triangle :exclamation: If it does, you can unmonitor it while you run the season search, or you can change the series to standard and rerun the search (just change it back afterwards).
Thanks for replying. How do i update scene mapping?
hmm it appears i just needed to unmonitor the last three unreleased episodes. Thanks for telling me about the absolute numbering thing. Really useful info.
System > Tasks > recycle button next to update scene mapping
Just make sure to re monitor them, otherwise they won’t get automatically downloaded when they are updated properly.
yeah, it is annoying. @markus101, Is there anyway to fix that? It would seem that Sonarr could either ignore the episode, or just search with the SxxExx format when that happens. Is really annoying for things like the specials under One Piece. I have to change the series out of anime to search for them, because none of them have absolute episode numbers (and there are 38 of them) but the other 1000 episodes do.
Do you know if it will still grab episodes automatically if one of them doesnt have an absolute number. Episode 72 for example hasn`t been released by the release group im using. Would that still get grabbed even if 73 is broken?
Not at the moment, looking at what we can do there in v3 though.
Yes, if 72 is fine, 73 has no impact on it.
