Sonarr no longer able to connect to Plex
Sonarr version (exact version): 2.0.0.4389
OS: Windows 7
((Debug logs)):
Description of issue: Not exactly sure when this started happening, but Sonarr is no longer able to connect to Plex to notify it of new episodes. I get the following error in the log:
Message
            Unable to connect to Plex Server: Value cannot be null.
Parameter name: source: Value cannot be null.
                Exception
                System.ArgumentNullException: Value cannot be null.
   at System.Linq.Enumerable.Where[TSource](IEnumerable`1 source, Func`2 predicate)
   at NzbDrone.Core.Notifications.Plex.PlexServerProxy.GetTvSections(PlexServerSettings settings) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Notifications\Plex\PlexServerProxy.cs:line 47
   at NzbDrone.Core.Notifications.Plex.PlexServerService.GetSections(PlexServerSettings settings) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Notifications\Plex\PlexServerService.cs:line 64
   at NzbDrone.Core.Notifications.Plex.PlexServerService.Test(PlexServerSettings settings) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Notifications\Plex\PlexServerService.cs:line 152
Nothing has changed with my Plex configuration other than version updates, but again I’m not sure exactly when it started happening so I can’t say if it was after a specific update. I also haven’t changed anything in the Sonarr Connections setting for Plex.
Ah, ok, thanks.
