Sonarr multi restriction behavior
Mono version (if Sonarr is not running on Windows):4.2.1 (Stable 4.2.1.102/6dd2d0d Mon Nov 30 14:47:31 CET 2015)
OS: DSM 5.2-5592 Update 4
Debug logs (posted to hastebin or similar): Not a problem requiring log
i’m confused in how multi restrictions is working in sonarr.
I want to use global restrictions with no tags.
How are thoses restrictions used and in which order ?
will it work like in this screenshot
There is no ordering for restrictions. Within a rule the Must Contain is ORed, so the first rule would be web OR 720 and between rules the rules are ANDed.
The first two rules would be either web AND 720 OR web and dimension.
The first rule is better served in a quality profile, the 2nd rule would only work for qualities that dimension releases, so it would limit would would be grabbed. Your 3rd rule would need to be 3 separate rules linked to series via tags, if 8-bit is absent from releases you should use must not contain 10-bit.
Thank for the reply. i assumed restrictions were ANDed. I will take your feedback to change my restrictions the way i want them.
