Sonarr version: 2.0.0.5344
Mono version: 5.10.1.57
OS: FreeNAS 11.3
Here is how I want the setup to be:
Download Client: Transmission, it is straight forward
Indexer: Jackett
Organizer: Sonarr
Media Server: PLEX
Transmission to download files to a folder (/mnt/Media/Media-Dataset/Transmission-Dataset), where then Sonarr takes care of the organizing of the TV Shows.
So mainly, i want Sonarr to move the shows to two different locations:
- for 16+ Shows to be moved to (/mnt/Media/Media-Dataset/TV-Shows/Parents)
- For Kids Shows to be moved to (/mnt/Media/Media-Dataset/TV-Shows/Kids)
I managed to do all the following steps, but I am not sure how to add the shows in Sonarr and make it organize them the way I need. I know there is a permission aspects for this and I believe there should be even a mounting points as well.
I did this, stopped Sonarr and did a mounting points from (/mnt/Media/Media-Dataset/Transmission-Dataset) to Sonarr media mount, but i do not see them and it is not what i am looking for
All steps are done through GUI,
FreeNAS 11.3
A) within FreeNAS 11.3:
- Created Group Transmission GID: 921
- Created Username t.admin UID: 921
- Created Pool named Media
- Created Dataset named Media-Dataset (/mnt/Media/Media-Dataset), Share Type: SMB
- In Media-Dataset ACL, changed the user to t.admin and Group to Transmission
- Created SMB Share /mnt/Media/Media-Dataset, disabled Shadow Copies
- In Media-Dataset ACL, Assigned my user with access to view it
- Created Dataset named Transmission-Dataset (/mnt/Media/Media-Dataset/Transmission-Dataset), Share Type: SMB
- In Transmission-Dataset ACL, changed the user to t.admin and Group to Transmission
- In Plugin and Jail selected Media as storage
- Installed Sonnar, Jail named as (Sonarr_J)
- Installed Transmission, Jail named as (Transmission_J)
- Installed Jackett, Jail named as (Jackett_J)
- Stopped Jackett, to update it to DHCP, unset NAT (forget to do it while installing)
- Started Jackett
- Stopped Transmission, to mount Source: /mnt/Media/Media-Dataset/Transmission-Dataset, Destination: /mnt/Media/iocage/jails/Transmission_J/root/media
- Started Transmission
B) Within Jackett:
- Checked for updates and updated the version as the one installed was old
- Added my indexers
C) within Sonarr:
- Added the indexers from Jacketts (http://192.168.3.43:9117/api/v2.0/indexers/all/results/torznab/)
- Added other indexers
- Added Download Client (Transmission)
- After doing D)02.
D) Within Transmission:
- After doing A)18. Changed Download to: /media
- Tested downloading a torrent file to check if it will download to Transmission-Dataset >> File was downloaded correctly
