Sonarr version (3.0.10.1567):
Mono version (6.12.0.199.macos10.xamarin.universal):
OS: 13.2.1 (22D68)
Debug logs: ~/.config/Sonarr/
Hi I switched from an MBP to a Mac mini Pro M2 recently and reinstalled most stuff from fresh… Radarr, Prowlarr are good to go but Sonarr is giving me an issue. It’s running but unable to view the webserver UI in localhost from all the different browsers. So I was unable to set it up. I uninstalled and reinstalled a few times.
Already chmod it and checked that the port is not blocked:
drwxr-xr-x@ 6 username staff 192 Jul 7 19:47 Contents
-rwxr-xr-x@ 1 username staff 103408 Jul 7 19:53 Sonarr
Connection to 127.0.0.1 port 8989 [udp/*] succeeded!
Yet I still got error in the logs every time: “[Fatal] ConsoleApp: Address already in use. This can happen if another instance of Sonarr is already running another application is using the same port (default: 8989) or the user has insufficient permissions”.
Full log is here:
I’ve been at it for weeks. Please help me. I’m sure you can. Thanks! ヅ
