Sonarr is not grabbing some episodes
Last night Sonarr only grabbed 6 out of the 9 shows and had to manually download the rest. The 3 it missed was The Magicians, Damien and 11.22.63. I looked into the log files and at one point it was not able to connect to any of the indexers. Then when it did it came back with:
Unable to set last write time: The process cannot access the file ‘E:\TV Shows\The Magicians (2016)’ because it is being used by another process.
The only apps that access these folders are Sonarr and Sab v1.0. (Running on Win 7 64-bit) Anyone else having this problem?
If your indexers are having issues or something prevents Sonarr from connecting to them, missing episodes is likely. Knowing why they failed would be the first step.
Likely because the folder was open in Windows Explorer which locked it from being updated (a rather annoying issue, but it can be ignored if it doesn’t happen on every import).
OK. Everything downloaded correctly last night, so I’ll keep an eye on those 3 episodes next week and see what happens. Perhaps it was just a fluke. Thanks
