Sonarr indexers setup confusion need help
I am using SABnzbd and have been following this guide to set up
I am on the sonarr set up and copy and pasting the instructions here so you can see what im confused on
Indexers tabWe need to start adding in our indexers. Open up that text file with our API keys that we made in step 4 and use the big plus icon to add indexers. Go down the list below and keep adding indexers.Click the Presets drop-down listed on Newznab and select OZnzb.com. Paste in your API key. Click the down arrow next to Save and select save and add.Click Newznab (not the Presets). Enter NZB Zombie as the Name. Set the URL to http://nzbzombie.com. Paste in your API key. Select save and add again.Click Newznab (not the Presets). Enter Usenet-Crawler for the Name. Set the URL to http://www.usenet-crawler.com/. Paste in your API key. Click save and add again.If you are into Anime, click Animezb and choose save and add.Click Wombles and then choose save and add.If you are using torrents, click Eztv. Click save and add.If you are using torrents, click KickassTorrents. Click save.
When its asking for the API would this be the API in my SABnbd. If so I have copied and pasted both separate times and it tells me the API is wrong i have also refreshed my API and it did nothing to fix the problem. So far this is the most confusing part and i have searched for instruction to make it more clear all over and cant find anything. Please help
Miles
You need the api of the newznab that you are using. If you are using the usenet-crawler.com then you nee the API of that. It is not the api of sabnzbd
thank you the tutorial i am following confused me a bit because i could never find a API for OZnzb.com and it says i got it earlier but I never saw that I was given it nor could i find it so it left me confused
