Sonarr Version: 3.0.10.1567
Mono Version: 6.12.0.182
OS: Synology Nas 220+ DSM 7.1.1-42962
Debug logs :
error code=“900” description=“Jackett.Common.IndexerException: Exception (extratorrent-st): Error connecting to FlareSolverr server: System.Net.Http.HttpRequestException: Connection refused (192.168.0.212:8191)
—> System.Net.Sockets.SocketException (111): Connection refused
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken)
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token)
at System.Net.Sockets.Socket.<ConnectAsync>g__WaitForConnectWithCancellation|277_0(AwaitableSocketAsyncEventArgs saea, ValueTask connectTask, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.AddHttp11ConnectionAsync(HttpRequestMessage request)
at System.Threading.Tasks.TaskCompletionSourceWithCancellation1.WaitWithCancellationAsync(CancellationToken cancellationToken)
 at System.Net.Http.HttpConnectionPool.GetHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
 at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
 at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
 at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
 at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken)
 at FlareSolverrSharp.Solvers.FlareSolverr.<>c__DisplayClass10_0.<<SendFlareSolverrRequest>b__0>d.MoveNext()
 ---> FlareSolverrSharp.Exceptions.FlareSolverrException: Error connecting to FlareSolverr server: System.Net.Http.HttpRequestException: Connection refused (192.168.0.212:8191)
 ---> System.Net.Sockets.SocketException (111): Connection refused
— End of stack trace from previous location —
at FlareSolverrSharp.Utilities.SemaphoreLocker.LockAsync[T](Func1 worker)
 at FlareSolverrSharp.Solvers.FlareSolverr.SendFlareSolverrRequest(HttpContent flareSolverrRequest)
 at FlareSolverrSharp.Solvers.FlareSolverr.Solve(HttpRequestMessage request, String sessionId)
 at FlareSolverrSharp.ClearanceHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
 at Jackett.Common.Utils.Clients.HttpWebClient2.Run(WebRequest webRequest) in /home/(removed)/work/1/s/src/Jackett.Common/Utils/Clients/HttpWebClient2.cs:line 179
 at Jackett.Common.Utils.Clients.WebClient.GetResultAsync(WebRequest request) in /home/(removed)/work/1/s/src/Jackett.Common/Utils/Clients/WebClient.cs:line 219
 at Jackett.Common.Indexers.BaseWebIndexer.RequestWithCookiesAsync(String url, String cookieOverride, RequestType method, String referer, IEnumerable
1 data, Dictionary2 headers, String rawbody, Nullable
1 emulateBrowser) in /home/(removed)/work/1/s/src/Jackett.Common/Indexers/BaseIndexer.cs:line 535
at Jackett.Common.Indexers.CardigannIndexer.PerformQuery(TorznabQuery query) in /home/(removed)/work/1/s/src/Jackett.Common/Indexers/CardigannIndexer.cs:line 1428
at Jackett.Common.Indexers.BaseIndexer.ResultsForQuery(TorznabQuery query, Boolean isMetaIndexer) in /home/(removed)/work/1/s/src/Jackett.Common/Indexers/BaseIndexer.cs:line 332
at Jackett.Common.Indexers.BaseWebIndexer.ResultsForQuery(TorznabQuery query, Boolean isMetaIndexer) in /home/(removed)/work/1/s/src/Jackett.Common/Indexers/BaseIndexer.cs:line 704
at Jackett.Server.Controllers.ResultsController.Torznab(TorznabRequest request) in /home/(removed)/work/1/s/src/Jackett.Server/Controllers/ResultsController.cs:line 466” />
2023-04-12 16:13:50.9|Warn|HttpClient|HTTP Error - Res: [GET] http://192.168.0.212:9117/api/v2.0/indexers/badasstorrents/results/torznab/api?t=tvsearch&cat=5000&extended=1&apikey=(removed)&offset=0&limit=100&q=SWV%20and%20XSCAPE%20The%20Queens%20Of%20RandB&season=1&ep=5: 400.BadRequest (11528 bytes)
Description of issue: I am running my Sonarr and Jackett on the same server, when i add an indexer on jackett it tests just fine, when added to Sonarr it tests fine again but the moment i search for a series it gives me an error.
