Sonarr version (exact version): Mono version (if Sonarr is not running on Windows): OS: Debug logs: Description of issue:
I am trying to integrate Sonarr and FileFlows. I have Sonarr downloading files to a Complete folder , the FileFlows performs on the file, then the file is moved to a Converted folder
However, Sonarr keeps giving the error that the file isn’t accesible even though I have mappings correct and the Converted folder appears as an option wihen doing a Remote Mapping that has Sonarr looking for files in the converted folder ie remote mapping is to complete folder and local mapping is to converted folder.
The user you’re logged in as doesn’t matter in this instance, but the is an MKV for Chicago PD directly in that folder, not in the job folder that your download client indicates it should be in.
