OS:
got a question im able to import my media manually. but sonarr will not move media /mnt/hdd/downloads/qbittorrent/ to /mnt/unionfs/qbittorrent/ in my remote path settings.
ive been reading but cant find any info on what the problem is.
https://sonarr.greatshedbox.com/logfile/sonarr.txt
Remote path mapping doesn’t relate to moving. It tells Sonarr instead of looking at REMOTE to look at LOCAL for mapped drives, etc
ok so how do i fix it or the problem @Austin
this is what i get:
Carter.S02E02.iNTERNAL.1080p.HDTV.h264-SFM
- No files found are eligible for import in /mnt/unionfs/qbittorrent/Carter.S02E02.iNTERNAL.1080p.HDTV.h264-SFM
That is a loaded question based on your confugration
Mine:
Deluge monitors a folder, grabs the file & downloads it (manual)
Sonarr sends the report to Deluge when it finds something (automatic)
I have post-processing scripts that handle the media (ico files, rar files, zip files, check for video corruption, etc) so the script makes a copy of the file on “T:\TV Shows\Complete” after post-proceessing) and then moves the original to “S:\”
Since i dont want sonarr to mess up my seed on “S:\” i have a map telling it to look in “T:\TV Shows\Complete” instead of “S:\”
So it grabs it from the T drive, renames it & moves it to the path specific when i added the show.
The reason that is needed is because Deluge is telling Sonarr it is located at “S:\” since that is how deluge is setup to seed.
Without knowing your configuration and processing, it is hard to assist bud
are you talking about my sonnar config or my qbittorrent config (or both)???
Well both… A working example as the one i gave would also be helpful…
Where in this process does the file get moved to /mnt/unionfs/qbittorrent/ that requires the mapping?
Do you have post processing scripts that move it?
Do you have your media software (Plex, Kodi, etc) pointing to the same place you seed from (appears to be /mnt/hdd/downloads/qbittorrent/)?
To be sure, whare are you seeding from?
It appears you have the unionfs path set as a copy path but not on so it wont be copied there by qbit
post processing script: no
media software point to sonarr: yes
seeding from: idk???
kinda of a noob @Austin
