Sonarr ignoring indexer results
Sonarr version (exact version): 4.0.14.2938
Mono version (if Sonarr is not running on Windows): -
OS: Win10ProEN
Debug logs: https://gist.github.com/dreamland75/78899cb1dc0a3c11c4ce65bc587849c9.js
Description of issue: When searching for specific series, that are available via the indexer “indexers/g*y-torrents” (see log), they don’t show up in the search results and therefore are not downloaded.
When I search it in Jackett itself, it can be found.
Indexer is enabled, passes the test, has a high priority and the correct categories, in which the series can found, is selected.
Sonarr isn’t ignoring them, it just can’t find them because they’re named in a way that Sonarr does not understand or support.
