Sonarr version (exact version) 2.0.0.5225:
Mono version (if Sonarr is not running on Windows) 3.10.0:
Raspberry 3:
happy to supply once Sonarr works.
I am not sure if the two are related but the first issue I am getting is that I am getting a “This page can’t be displayed” message every time I try to log into my Sonarr via the Http://IP Address:8989.
if I reboot my raspberry then I am able to get in for about 5 mins then I get the same error.
the second error I am getting is that for some reason, the Sonarr application is reporting that it can’t find the ‘Missing root folder: /home/pi/tank/TV_Shows’ folders for the TV shows, but I have added a new TV show and this sees the drive with no issues. I am also able to FTP into the Raspberry via Putty and I can see the mount home drive with no issues.
I have other applications running on the Raspberry ’ Deluge ’ is is working fine, and also VPN.
my current storage is
4.0G /media/pi/ExtStorage/complete
7.4G /media/pi/ExtStorage/downloading
12G total
pi@raspberrypi:~ $ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 7.2G 4.9G 2.1G 71% /
devtmpfs 481M 0 481M 0% /dev
tmpfs 486M 4.0K 486M 1% /dev/shm
tmpfs 486M 6.7M 479M 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 486M 0 486M 0% /sys/fs/cgroup
/dev/sda1 30G 12G 17G 41% /media
/dev/mmcblk0p1 63M 22M 42M 35% /boot
tmpfs 98M 0 98M 0% /run/user/1000
//192.168.0.7/media 11T 6.1T 4.6T 57% /home/pi/tank
pi@raspberrypi:~ $ sudo fdisk -l
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram4: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram5: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram6: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram7: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram8: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram9: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram10: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram11: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram12: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram13: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram14: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram15: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk0: 7.4 GiB, 7948206080 bytes, 15523840 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x4ce00e54
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 8192 137215 129024 63M c W95 FAT32 (LBA)
/dev/mmcblk0p2 137216 15523839 15386624 7.3G 83 Linux
Disk /dev/sda: 29.8 GiB, 32019316736 bytes, 62537728 sectors
Disklabel type: dos
Disk identifier: 0xc3072e18
/dev/sda1 32 62537727 62537696 29.8G 7 HPFS/NTFS/exFAT
