Sonarr fails to start
Sonarr version (exact version): v2.0.0.4146
OS: Win 7 64-bit
((Debug logs)) (posted to hastebin or similar): http://hastebin.com/uqoxegopuf.tex
A couple of days ago sonarr just stopped working. The logs mentions something about failed to check firewall. I don’t have windows firewall enabled and I tried running Sonarr with Comodo disabled. Running “NzbDrone.Console” gave same results.
For the error: 800706d9 There are no more endpoints available from the endpoint mapper. Microsoft said to make sure the following are running:
Remote Procedure Call (RPC)
Remote Procedure Call (RPC) Locator
Both are running
I tried re-imaging the OS drive but this didn’t work either. Any ideas?
Using a copy of what was already installed or a fresh install?
The message is just a warning so it should start fine.
16-6-13 08:16:38.3|Info|ProcessProvider|Opening URL [http://localhost:8989]
Is that the last line in the log file?
Couple related things:
http://stackoverflow.com/a/12600402/882971 - this one mentions it being a problem with the firewall
http://wmug.co.uk/wmug/b/peter_egerton/archive/2013/12/11/bgbserver-log-error-in-firewalldetection - this one says it can be ignored
What changed recently?
