Version 2.0.0.5228
Windows 10 64bit Home Build Version 1803 Build 17134.228
https://drive.google.com/open?id=1g93gZChP5Dkwc_d_MNh8oIikwGhpIST6
Screenshot HERE and HERE
I noticed Sonarr was downloading an episode of a TV series at a specific quality (720p-WebDL) and shortly afterwards deletes it and download the same episode with the same quality. Makes no sense
Please post an unaltered picture of the history for that particular episode, also your logs don’t show anything (and aren’t debug logs ).
As for the logs, I did not have debug on before, so not much to go on there. Here are the screenshots
1
2
You need to open the episode details modal to get the history for that single episode.
It’s because it was a repack; a repack or proper will replace an episode of the same quality, they’re used to fix a variety of issues with releases.
You can turn off Download Propers if you want to opt out of that behaviour. (It’s an advanced setting in Media Management).
system
Closed
October 30, 2018, 8:53pm
7
