Sonarr version 2.0.0.5338:
Windows 10 Pro 1903:
** log files are after description
Description of issue: I recently migrated my DVR program from Sickbeard. My Plex server is running on a remote server and the media folder is a mapped drive share. I found the way to get Sonarr to talk to that with no problem. So far Sonarr has been great about collecting the shows I want but I am having trouble getting the post download processing to place each episode int hte correct folder.
Each show has its own folder like \server\media\TV\tv_show_name
Sonarr shows the correct path for each of the shows, but after processing the file it seems to place them like this
\server\media\TV\downloaded_episode_in_own_folder\all_downloaded_files_not_renamed
I am basically having to manually rename and move each episode to the proper folder.
After I do that, Sonarr scans the right folder and sees that all of the episodes are there, and Plex scans the folder and displays them as normal.
I probably missed something in the configuration process, but I haven’t found it. the log files seem to say it doesn’t have rights to the folders, but it is using the same credentials I use to move and write in those shares.
Thanks in advance
logfiles
19-11-10 18:32:48.9|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\His.Dark.Materials.S01E02.1080p.HEVC.x265-MeGusta-Obfuscated
19-11-10 18:32:48.9|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\Doctor.Who.2005.S08.Live.The.Next.Doctor.1080p.BluRay.x264-SHORTBREHD
19-11-10 18:34:16.7|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\turn.s03e08.1080p.bluray.x264.1-justwatch-Obfuscated
19-11-10 18:34:16.7|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\TURN.Washingtons.Spies.S02E06.1080p.WEB-DL.DD5.1.H.264-QUEENS
19-11-10 18:34:16.7|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\turn.s04e03.1080p.bluray.x264.1-rovers-Obfuscated
19-11-10 18:34:16.7|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\turn.s03e07.1080p.bluray.x264.1-justwatch-Obfuscated
19-11-10 18:34:16.7|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\turn.s04e02.1080p.bluray.x264.1-rovers-Obfuscated
19-11-10 18:34:16.8|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\TURN.Washingtons.Spies.S02E05.Sealed.Fate.1080p.WEB-DL
19-11-10 18:34:16.8|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\turn.s03e06.1080p.bluray.x264.1-justwatch-Obfuscated
19-11-10 18:34:16.8|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\turn.s04e01.1080p.bluray.x264.1-rovers-Obfuscated
19-11-10 18:34:16.8|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\TURN.Washingtons.Spies.S02E03.False.Flag.1080p.WEB-DL.DD5.1.H.264-QUEENS
19-11-10 18:34:16.8|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\turn.s03e05.1080p.bluray.x264.1-justwatch-Obfuscated
19-11-10 18:34:16.8|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\TURN.Washingtons.Spies.S02E02.Hard.Boiled.1080p.WEB-DL.DD5.1.H.264-QUEENS
19-11-10 18:34:16.8|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\turn.s03e04.1080p.bluray.x264.1-justwatch-Obfuscated
19-11-10 18:34:16.8|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\turn.s03e03.1080p.bluray.x264.1-justwatch-Obfuscated
19-11-10 18:34:16.8|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\turn.s03e02.1080p.bluray.x264.1-justwatch-Obfuscated
19-11-10 18:34:16.8|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\Turn.S02E10.1080p.BluRay.x264-ROVERS
19-11-10 18:34:16.8|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\TURN.S01.1080p.BluRay.x264-FLHD
19-11-10 18:34:16.8|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\turn.s03e01.1080p.bluray.x264.1-justwatch-Obfuscated
19-11-10 18:34:16.8|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\Turn.S02E09.1080p.BluRay.x264-ROVERS
19-11-10 18:34:16.8|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\Turn.S02E04.1080p.BluRay.x264-ROVERS
19-11-10 18:34:16.8|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\Turn.S02E01.1080p.BluRay.x264-ROVERS
19-11-10 18:34:16.8|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\His.Dark.Materials.S01E02.1080p.HEVC.x265-MeGusta-Obfuscated
19-11-10 18:34:16.8|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\Doctor.Who.2005.S08.Live.The.Next.Doctor.1080p.BluRay.x264-SHORTBREHD
19-11-10 18:35:48.7|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\turn.s04e04.1080p.bluray.x264.1-rovers-Obfuscated
19-11-10 18:35:48.7|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: Z:\TV\turn.s03e08.1080p.bluray.x264.1-justwatch-Obfuscated\
