Sonarr crashing 15-30 seconds after launching
Mono version (if Sonarr is not running on Windows): 6.6.0.161
OS: macOS 10.15.7
Description of issue: Sonarr crashing 15-30 seconds after launching. After checking sonarr.txt log, it shows the following error
Full Log: https://pastebin.com/FYrvRBkF
Troubleshooting done
  1. Uninstalled Sonarr
  2. Removed all Sonarr contents folder
  3. Deleted entire folder ~/.config/NzbDrone
  4. Re-installed Sonarr
  5. Rebooted server
I haven’t seen this happen before, but have you given /bin/sh full disk access?
Yes /bin/sh has full disk access. Sonarr.app still crashes about 15 seconds into launching.
It’s a bit of a long shot, but downgrading mono to 5.20 may help here, alternatively I’m curious if the v3 beta helps (no longer requires the bin/sh full access piece), otherwise I’m at a loss here.
Yeah, cool I will give it a shot. Thanks for your help.
so here is something new… Sonarr process still crashes, however the web interface remains available… I can’t add any TV shows, but I can edit some of the settings like indexers, and such… weird!
If Sonarr crashes there is no way editing would be successful, are there just multiple instances running causing issues?
agreed, and definitely only 1 instance. I rebooted multiple times just to make sure.
Well the issue has been fixed, not sure which one of these did it, but ill explain what I did…
I noticed there was a Sonarr.app in /opt/homebrew-cask/Caskroom/sonarr/latest
I remove this entire folder /opt/homebrew-cask/Caskroom/sonarr/
Not sure how that happened, I never use homebrew. Also when I went to go launch the Sonarr.app in that folder previously (before removing the entire folder) it asked me to accept an xcode license agreement. Not sure if Sonarr uses xcode, but if it does, perhaps that could prevent it from running correctly?
