Currently my sabnzbd resides at https:///sabnzbd via a webproxy and I can’t seem to connect to it from Sonarr and I suspect its because of the custom webroot. How do I make this happen? (It works if I connect to localhost:8080)
Thanks!
Thanks!
You are correct, its because of the custom web root. Why is using localhost:8080 not acceptable?
Thanks for the quick response!
I suppose it is acceptable, I noticed when I had an error on my config, it opened a page on SABNZBD so I could correct it, and it went to localhost:8080. Since I was remote it obviously failed. I thought there might be more integration that would be useful if I were remote.
