OS: Windows 11
Debug logs: none
Description of issue: Whenever Sonarr downloads an MKV file, it’s unable to move its destination, remove it from the download client, or rename it automatically; other files appear to be fine
As if there’s nothing at all in the logs? There should at least be a try by sonarr and it will tell you why it failed. There’s nothing special about that extension in sonarr.
Is there a way to force a log of some type? My logs folder is empty
You’re saying under System / Logs in Sonarr there is nothing there to download?
OK, got a log file, this is from this evening, have just downloaded and MKV file again that isn’t moving:
2023-09-09 17:37:32.9|Info|ExistingMetadataImporter|Found 0 existing metadata files
2023-09-09 17:37:32.9|Info|ExistingSubtitleImporter|Found 0 existing subtitle files
2023-09-09 17:37:32.9|Info|ExistingOtherExtraImporter|Found 0 existing other extra files
2023-09-09 17:37:32.9|Info|ExistingExtraFileService|Found 0 possible extra files, imported 0 files.
2023-09-09 17:39:21.6|Info|RssSyncService|Starting RSS Sync
2023-09-09 17:41:01.6|Warn|Torznab|KickassTorrents.to server is currently unavailable. http://127.0.0.1:9000/api/v2.0/indexers/kickasstorrents-to/results/torznab/api?t=tvsearch&cat=5000,103583&extended=1&apikey=(removed)&offset=0&limit=100 The operation has timed out
2023-09-09 17:41:01.6|Info|DownloadDecisionMaker|Processing 52 releases
2023-09-09 17:41:01.7|Info|RssSyncService|RSS Sync Completed. Reports found: 52, Reports grabbed: 0
2023-09-09 17:51:21.9|Info|RssSyncService|Starting RSS Sync
2023-09-09 17:51:22.2|Info|DownloadDecisionMaker|Processing 52 releases
2023-09-09 17:51:22.3|Info|RssSyncService|RSS Sync Completed. Reports found: 52, Reports grabbed: 0
2023-09-09 18:01:52.2|Info|RssSyncService|Starting RSS Sync
2023-09-09 18:03:32.2|Warn|Torznab|KickassTorrents.to server is currently unavailable. http://127.0.0.1:9000/api/v2.0/indexers/kickasstorrents-to/results/torznab/api?t=tvsearch&cat=5000,103583&extended=1&apikey=(removed)&offset=0&limit=100 The request was aborted: The operation has timed out.
2023-09-09 18:03:32.2|Info|DownloadDecisionMaker|Processing 52 releases
2023-09-09 18:03:32.3|Info|RssSyncService|RSS Sync Completed. Reports found: 52, Reports grabbed: 0
2023-09-09 18:13:52.5|Info|RssSyncService|Starting RSS Sync
2023-09-09 18:13:59.0|Info|DownloadDecisionMaker|Processing 57 releases
2023-09-09 18:13:59.1|Info|RssSyncService|RSS Sync Completed. Reports found: 57, Reports grabbed: 0
2023-09-09 18:24:22.7|Info|RssSyncService|Starting RSS Sync
2023-09-09 18:24:22.8|Info|DownloadDecisionMaker|Processing 57 releases
2023-09-09 18:24:22.9|Info|RssSyncService|RSS Sync Completed. Reports found: 57, Reports grabbed: 0
2023-09-09 18:34:23.0|Info|RssSyncService|Starting RSS Sync
2023-09-09 18:36:03.0|Warn|Torznab|KickassTorrents.to server is currently unavailable. http://127.0.0.1:9000/api/v2.0/indexers/kickasstorrents-to/results/torznab/api?t=tvsearch&cat=5000,103583&extended=1&apikey=(removed)&offset=0&limit=100 The request was aborted: The operation has timed out.
2023-09-09 18:36:03.0|Info|DownloadDecisionMaker|Processing 57 releases
2023-09-09 18:36:03.1|Info|RssSyncService|RSS Sync Completed. Reports found: 57, Reports grabbed: 0
2023-09-09 18:46:23.3|Info|RssSyncService|Starting RSS Sync
2023-09-09 18:46:23.4|Info|DownloadDecisionMaker|Processing 57 releases
2023-09-09 18:46:23.5|Info|RssSyncService|RSS Sync Completed. Reports found: 57, Reports grabbed: 0
2023-09-09 18:56:23.6|Info|RssSyncService|Starting RSS Sync
2023-09-09 18:56:24.9|Warn|Torznab|Indexer The Pirate Bay rss sync didn't cover the period between 9/9/2023 5:00:07 PM and 9/9/2023 5:13:33 PM UTC. Search may be required.
2023-09-09 18:58:03.6|Warn|Torznab|1337x server is currently unavailable. http://127.0.0.1:9000/api/v2.0/indexers/1337x/results/torznab/api?t=tvsearch&cat=5000,5030,5040,5070,5080,100005,100006,100007,100009,100041,100074,100075&extended=1&apikey=(removed)&offset=0&limit=100 The request was aborted: The operation has timed out.
2023-09-09 18:58:03.6|Warn|Torznab|KickassTorrents.ws server is currently unavailable. http://127.0.0.1:9000/api/v2.0/indexers/kickasstorrents-ws/results/torznab/api?t=tvsearch&cat=5000,103583&extended=1&apikey=(removed)&offset=0&limit=100 The request was aborted: The operation has timed out.
2023-09-09 18:58:03.6|Info|DownloadDecisionMaker|Processing 19 releases
2023-09-09 18:58:03.6|Info|RssSyncService|RSS Sync Completed. Reports found: 19, Reports grabbed: 0
2023-09-09 19:08:23.9|Info|RssSyncService|Starting RSS Sync
2023-09-09 19:10:03.9|Warn|Torznab|1337x server is currently unavailable. http://127.0.0.1:9000/api/v2.0/indexers/1337x/results/torznab/api?t=tvsearch&cat=5000,5030,5040,5070,5080,100005,100006,100007,100009,100041,100074,100075&extended=1&apikey=(removed)&offset=0&limit=100 The request was aborted: The operation has timed out.
2023-09-09 19:10:03.9|Warn|Torznab|KickassTorrents.ws server is currently unavailable. http://127.0.0.1:9000/api/v2.0/indexers/kickasstorrents-ws/results/torznab/api?t=tvsearch&cat=5000,103583&extended=1&apikey=(removed)&offset=0&limit=100 The request was aborted: The operation has timed out.
2023-09-09 19:10:03.9|Info|DownloadDecisionMaker|Processing 19 releases
2023-09-09 19:10:03.9|Info|RssSyncService|RSS Sync Completed. Reports found: 19, Reports grabbed: 0
2023-09-09 19:20:24.2|Info|RssSyncService|Starting RSS Sync
2023-09-09 19:20:24.3|Info|DownloadDecisionMaker|Processing 19 releases
2023-09-09 19:20:24.3|Info|RssSyncService|RSS Sync Completed. Reports found: 19, Reports grabbed: 0
2023-09-09 19:30:24.5|Info|RssSyncService|Starting RSS Sync
2023-09-09 19:32:04.6|Warn|Torznab|1337x server is currently unavailable. http://127.0.0.1:9000/api/v2.0/indexers/1337x/results/torznab/api?t=tvsearch&cat=5000,5030,5040,5070,5080,100005,100006,100007,100009,100041,100074,100075&extended=1&apikey=(removed)&offset=0&limit=100 The request was aborted: The operation has timed out.
2023-09-09 19:32:04.6|Warn|Torznab|KickassTorrents.ws server is currently unavailable. http://127.0.0.1:9000/api/v2.0/indexers/kickasstorrents-ws/results/torznab/api?t=tvsearch&cat=5000,103583&extended=1&apikey=(removed)&offset=0&limit=100 The request was aborted: The operation has timed out.
2023-09-09 19:32:04.6|Info|DownloadDecisionMaker|Processing 19 releases
2023-09-09 19:32:04.6|Info|RssSyncService|RSS Sync Completed. Reports found: 19, Reports grabbed: 0
2023-09-09 19:33:45.7|Info|ReleaseSearchService|Searching indexers for [My Adventures with Superman : S01E10]. 1 active indexers
2023-09-09 19:33:47.0|Info|DownloadDecisionMaker|Processing 18 releases
2023-09-09 19:33:55.0|Info|DownloadService|Report sent to qBittorrent. My.Adventures.with.Superman.S01E10.1080p.HEVC.x265-MeGusta[TGx]
2023-09-09 19:35:24.7|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: D:\Piracy\My.Adventures.with.Superman.S01E10.1080p.HEVC.x265-MeGusta[TGx]. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
2023-09-09 19:36:24.7|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: D:\Piracy\My.Adventures.with.Superman.S01E10.1080p.HEVC.x265-MeGusta[TGx]. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
And yes, the path does exist, D:\Piracy\My.Adventures.with.Superman.S01E10.1080p.HEVC.x265-MeGusta[TGx]
Some more:
2023-09-09 19:37:24.6|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: D:\Piracy\My.Adventures.with.Superman.S01E10.1080p.HEVC.x265-MeGusta[TGx]. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
2023-09-09 19:38:54.7|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: D:\Piracy\My.Adventures.with.Superman.S01E10.1080p.HEVC.x265-MeGusta[TGx]. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
2023-09-09 19:39:54.7|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: D:\Piracy\My.Adventures.with.Superman.S01E10.1080p.HEVC.x265-MeGusta[TGx]. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
2023-09-09 19:40:54.8|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: D:\Piracy\My.Adventures.with.Superman.S01E10.1080p.HEVC.x265-MeGusta[TGx]. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
2023-09-09 19:42:24.7|Info|RssSyncService|Starting RSS Sync
2023-09-09 19:42:24.9|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: D:\Piracy\My.Adventures.with.Superman.S01E10.1080p.HEVC.x265-MeGusta[TGx]. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
2023-09-09 19:42:25.8|Warn|Torznab|Indexer The Pirate Bay rss sync didn't cover the period between 9/9/2023 5:43:33 PM and 9/9/2023 5:58:33 PM UTC. Search may be required.
2023-09-09 19:43:54.9|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: D:\Piracy\My.Adventures.with.Superman.S01E10.1080p.HEVC.x265-MeGusta[TGx]. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
2023-09-09 19:44:04.8|Warn|Torznab|KickassTorrents.to server is currently unavailable. http://127.0.0.1:9000/api/v2.0/indexers/kickasstorrents-to/results/torznab/api?t=tvsearch&cat=5000,103583&extended=1&apikey=(removed)&offset=0&limit=100 The operation has timed out
2023-09-09 19:44:04.8|Info|DownloadDecisionMaker|Processing 18 releases
2023-09-09 19:44:04.8|Info|RssSyncService|RSS Sync Completed. Reports found: 18, Reports grabbed: 0
2023-09-09 19:44:54.9|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: D:\Piracy\My.Adventures.with.Superman.S01E10.1080p.HEVC.x265-MeGusta[TGx]. Ensure the path exists and the user running Sonarr has the correct permissions to access this file/folder
Looking at old forum posts with the error, I stopped the sonarr service and re-ran the application itself, and it worked. Is this a proper fix, or is there a better, more permanent solution?
The error literally says what’s wrong. It’s a permissions issue.
The fact that it’s “fixed” when you stop the service and execute sonarr with your own account probably means that the service runs with a different account that can’t access that path.
Either change the permissions on the main download folder so the service account has access to it (and all folders below), change the service to run with a different account (yours?) which has access to the main download folder, or disable the service and auto-start sonarr when you log in so it runs under your own account. Whichever fits your use case best.
There is only one account on the computer, and it is my admin account?
Services typically don’t run as your own account, but a system account which might not have permissions on the folders you’re using.
