I’ve got a bizarre issue. Sonarr has subtracted 3 from the episode count for all episodes. It thinks that Steven Universe season 2 episode 20 should be S02E17. You can see the confusion by the system when I hover over the episode label. This breaks stuff because all the searching is done off this data. When I do a manual search I can see clearly that Sonarr is looking for E17 instead of E20. The debug log doesn’t look very helpful. Any ideas how I might fix this? Maybe there’s some way I can blow away Sonarr’s underlying data store and make it repopulate the show series info?
This just started happening recently, but I’ve had 2.0.0.3357 installed since July 20th.
15-9-24 19:20:53.8|Debug|NzbSearchService|Total of 4 reports were found for [Steven Universe : S02E17] from 2 indexers
15-9-24 19:20:53.8|Info|DownloadDecisionMaker|Processing 4 releases
15-9-24 19:20:53.8|Debug|Parser|Parsing string ‘Steven Universe S02E17 720p HDTV x264-W4F’
15-9-24 19:20:53.8|Debug|Parser|Episode Parsed. Steven Universe - S02E17
15-9-24 19:20:53.9|Debug|Parser|Language parsed: English
15-9-24 19:20:53.9|Debug|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for Steven Universe S02E17 720p HDTV x264-W4F
15-9-24 19:20:53.9|Debug|Parser|Quality parsed: HDTV-720p v1
15-9-24 19:20:53.9|Debug|Parser|Release Group parsed: W4F
15-9-24 19:20:53.9|Debug|ParsingService|Using Scene to TVDB Mapping for: Steven Universe - Scene: 2x17 - TVDB: 2x20
15-9-24 19:20:53.9|Debug|AcceptableSizeSpecification|Beginning size check for: Steven Universe S02E17 720p HDTV x264-W4F
15-9-24 19:20:53.9|Debug|AcceptableSizeSpecification|Item: Steven Universe S02E17 720p HDTV x264-W4F, meets size constraints.
15-9-24 19:20:53.9|Debug|BlacklistSpecification|Steven Universe S02E17 720p HDTV x264-W4F is blacklisted, rejecting.
15-9-24 19:20:53.9|Debug|LanguageSpecification|Checking if report meets language requirements. English
15-9-24 19:20:53.9|Debug|ReleaseRestrictionsSpecification|Checking if release meets restrictions: Steven Universe S02E17 720p HDTV x264-W4F
15-9-24 19:20:53.9|Debug|ReleaseRestrictionsSpecification|[Steven Universe S02E17 720p HDTV x264-W4F] No restrictions apply, allowing
15-9-24 19:20:53.9|Debug|QualityAllowedByProfileSpecification|Checking if report meets quality requirements. HDTV-720p v1
15-9-24 19:20:53.9|Debug|MinimumAgeSpecification|Not checking minimum age requirement for non-usenet report
15-9-24 19:20:53.9|Debug|RetentionSpecification|Not checking retention requirement for non-usenet report
15-9-24 19:20:53.9|Debug|DelaySpecification|Ignore delay for searches
15-9-24 19:20:53.9|Debug|HistorySpecification|Skipping history check during search
15-9-24 19:20:53.9|Debug|MonitoredEpisodeSpecification|Skipping monitored check during search
15-9-24 19:20:53.9|Debug|SeriesSpecification|Checking if series matches searched series
15-9-24 19:20:53.9|Debug|DownloadDecisionMaker|Release rejected for the following reasons: [Permanent] Release is blacklisted
15-9-24 19:20:53.9|Debug|Parser|Parsing string ‘Steven Universe S02E17 Historical Friction 720p WEB-DL AAC x264-ZED’
15-9-24 19:20:53.9|Debug|Parser|Episode Parsed. Steven Universe - S02E17
15-9-24 19:20:53.9|Debug|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for Steven Universe S02E17 Historical Friction 720p WEB-DL AAC x264-ZED
15-9-24 19:20:53.9|Debug|Parser|Quality parsed: WEBDL-720p v1
15-9-24 19:20:53.9|Debug|Parser|Release Group parsed: ZED
15-9-24 19:20:53.9|Debug|AcceptableSizeSpecification|Beginning size check for: Steven Universe S02E17 Historical Friction 720p WEB-DL AAC x264-ZED
15-9-24 19:20:53.9|Debug|AcceptableSizeSpecification|Item: Steven Universe S02E17 Historical Friction 720p WEB-DL AAC x264-ZED, meets size constraints.
15-9-24 19:20:53.9|Debug|BlacklistSpecification|Steven Universe S02E17 Historical Friction 720p WEB-DL AAC x264-ZED is blacklisted, rejecting.
15-9-24 19:20:53.9|Debug|ReleaseRestrictionsSpecification|Checking if release meets restrictions: Steven Universe S02E17 Historical Friction 720p WEB-DL AAC x264-ZED
15-9-24 19:20:53.9|Debug|ReleaseRestrictionsSpecification|[Steven Universe S02E17 Historical Friction 720p WEB-DL AAC x264-ZED] No restrictions apply, allowing
15-9-24 19:20:53.9|Debug|QualityAllowedByProfileSpecification|Checking if report meets quality requirements. WEBDL-720p v1
15-9-24 19:20:53.9|Debug|Parser|Parsing string ‘Steven Universe S02E17 Historical Friction 1080p WEB-DL AAC x264-ZED’
15-9-24 19:20:53.9|Debug|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for Steven Universe S02E17 Historical Friction 1080p WEB-DL AAC x264-ZED
15-9-24 19:20:53.9|Debug|Parser|Quality parsed: WEBDL-1080p v1
15-9-24 19:20:53.9|Debug|AcceptableSizeSpecification|Beginning size check for: Steven Universe S02E17 Historical Friction 1080p WEB-DL AAC x264-ZED
15-9-24 19:20:54.0|Debug|AcceptableSizeSpecification|Item: Steven Universe S02E17 Historical Friction 1080p WEB-DL AAC x264-ZED, meets size constraints.
15-9-24 19:20:54.0|Debug|BlacklistSpecification|Steven Universe S02E17 Historical Friction 1080p WEB-DL AAC x264-ZED is blacklisted, rejecting.
15-9-24 19:20:54.0|Debug|LanguageSpecification|Checking if report meets language requirements. English
15-9-24 19:20:54.0|Debug|ReleaseRestrictionsSpecification|Checking if release meets restrictions: Steven Universe S02E17 Historical Friction 1080p WEB-DL AAC x264-ZED
15-9-24 19:20:54.0|Debug|ReleaseRestrictionsSpecification|[Steven Universe S02E17 Historical Friction 1080p WEB-DL AAC x264-ZED] No restrictions apply, allowing
15-9-24 19:20:54.0|Debug|QualityAllowedByProfileSpecification|Checking if report meets quality requirements. WEBDL-1080p v1
15-9-24 19:20:54.0|Debug|MinimumAgeSpecification|Not checking minimum age requirement for non-usenet report
15-9-24 19:20:54.0|Debug|RetentionSpecification|Not checking retention requirement for non-usenet report
15-9-24 19:20:54.0|Debug|DelaySpecification|Ignore delay for searches
15-9-24 19:20:54.0|Debug|HistorySpecification|Skipping history check during search
15-9-24 19:20:54.0|Debug|MonitoredEpisodeSpecification|Skipping monitored check during search
15-9-24 19:20:54.0|Debug|SeriesSpecification|Checking if series matches searched series
15-9-24 19:20:54.0|Debug|DownloadDecisionMaker|Release rejected for the following reasons: [Permanent] Release is blacklisted
15-9-24 19:20:54.0|Debug|Parser|Parsing string ‘[AliQ] Steven Universe S02E17 Historical Friction [1080p WEB_DL x264].mp4’
15-9-24 19:20:54.0|Debug|Parser|Episode Parsed. Steven Universe - S02E17
15-9-24 19:20:54.0|Debug|Parser|Language parsed: English
15-9-24 19:20:54.0|Debug|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for [AliQ] Steven Universe S02E17 Historical Friction [1080p WEB_DL x264].mp4
15-9-24 19:20:54.0|Debug|Parser|Quality parsed: WEBDL-1080p v1
15-9-24 19:20:54.0|Debug|Parser|Release Group parsed: AliQ
15-9-24 19:20:54.0|Debug|ParsingService|Using Scene to TVDB Mapping for: Steven Universe - Scene: 2x17 - TVDB: 2x20
15-9-24 19:20:54.0|Debug|AcceptableSizeSpecification|Beginning size check for: [AliQ] Steven Universe S02E17 Historical Friction [1080p WEB_DL x264].mp4
15-9-24 19:20:54.0|Debug|AcceptableSizeSpecification|Item: [AliQ] Steven Universe S02E17 Historical Friction [1080p WEB_DL x264].mp4, meets size constraints.
15-9-24 19:20:54.0|Debug|BlacklistSpecification|[AliQ] Steven Universe S02E17 Historical Friction [1080p WEB_DL x264].mp4 is blacklisted, rejecting.
15-9-24 19:20:54.0|Debug|ReleaseRestrictionsSpecification|Checking if release meets restrictions: [AliQ] Steven Universe S02E17 Historical Friction [1080p WEB_DL x264].mp4
15-9-24 19:20:54.0|Debug|ReleaseRestrictionsSpecification|[[AliQ] Steven Universe S02E17 Historical Friction [1080p WEB_DL x264].mp4] No restrictions apply, allowing
