OS: Ubuntu 18.04 desktop
Debug logs: See pastebin
Hello,
I am a first time Ubuntu (18.04 GUI) and Docker user, so this project has been a learning experience for me. For the past 4 days I have been trying to get Sonarr to work correctly with Transmission-vpn on my Raid1 array.
What happens:
I select a show in Sonarr
Sonarr searches out to index
Transmission receives the torrent and downloads it.
Torrent finishes the downloads
Sonarr gives me import failed error (see logs)
If I go in and manually tell Sonarr to “Preview rename for all episodes” it breaks the episodes down into seasons but does not put them into a “series folder”.
File structure
Mount path of my raid array (referenced as MEDIA1 based upon enviro variables)=media/plex/Raid1
/media/plex/Raid1/Downloads/completed is where Transmission puts files when they are done. This is where I have the path set for each show (under the wrench icon on each show). Yet Sonarr gives me the import error.
/media/plex/Raid1/Downloads/incomplete is where Transmission puts the incomplete files. I can watch them get completed and moved to the “completed” folder.
Settings:
Rename episodes=ON
Series Folder Format={Series Title}
Create empty series folders=ON
Delete empty folders=ON (It does not do this after renaming folders)
Completed Download Handling= Enable is on
Completed Download Handling= Remove is on
At first I thought this was a permission issue, so I ran “sudo chmod -R ugo+rwx media/plex/Raid1” which should have given permission to do anything in the raid array.
LOGS: https://pastebin.com/WRZkEJWX
Docker file:https://pastebin.com/tAGBqiZE
