Sonarr version (exact version): 20191122-16
Mono version (if Sonarr is not running on Windows): 5.18.0.240-12
OS: DSM 6.2.2-24922 Update 4
Description of issue: I’ve been using Sonarr V3 on Synology with no issues for a couple of months or so now. It was all going fine until today, where everything seemingly went wrong. I was prompted to install an update, and after trying this I tried a lot of troubleshooting, including restarting the NAS, uninstalling and reinstalling Sonarr (both V3 and the current V2), using SSH to kill Mono and restart the packages, etc. After a while I tried uninstalling Sonarr, Radarr and Mono, then reinstalling, and this was clearly a mistake as now none of them are loading at all despite Package Centre saying they are running. Further details of my attempts to fix are here, suffice to say I have not had a good day with this so far. I’m desperate for any help, and I can’t get my head around SSH or anything like this at all so any instructions to try and fix this will need to be really clear please!
Edit: I tried using Pastebin and clearly whatever I did didn’t work. The logs I have are here; this was created by, as my Reddit helper suggested, entering “cd /volume1/@appstore/nzbdrone/var”, then “tail nzbdrone.log” into Putty. I don’t know if these are the correct logs to post?
