I’m trying to add dutplanet.net as a newznab indexer.
It seems to work fine at first, in that it finds releases with this indexer. But then when it tries to download the nzb it fails.
I get en errror getting nzb from indexer.
It’s creating these errors:
Downloading nzb for episode ‘Dokter Tinus S03E08 DUTCH 720p HDTV x264’ failed (609855): Unable to connect to the remote server
System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: A socket operation was attempted to an unreachable network 0.9.78.63:80
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
at System.Net.h.ttpWebRequest.GetResponse()
at NzbDrone.Common.h.ttp.h.ttpClient.Execute(h.ttpRequest request) in m:\BuildAgent1\work\328d72309b633a8\src\NzbDrone.Common\h.ttp\h.ttpClient.cs:line 86
at NzbDrone.Common.h.ttp.h.ttpClient.Get(h.ttpRequest request) in m:\BuildAgent1\work\328d72309b633a8\src\NzbDrone.Common\h.ttp\h.ttpClient.cs:line 155
at NzbDrone.Core.Download.UsenetClientBase`1.Download(RemoteEpisode remoteEpisode) in m:\BuildAgent1\work\328d72309b633a8\src\NzbDrone.Core\Download\UsenetClientBase.cs:line 57
The ip address it tries seems odd:
I also took a look at the xml coming from the dutplanet api. An item looks like this:
<item id="581331">
<id>581331</id>
<infoid>274687</infoid>
<title>Chef (2014) HDrip X264 AAC</title>
<category>Movies > HD</category>
<pubDate>Wed, 6 Aug 2014 19:39:37</pubDate>
<guid isPermaLink="true">581331</guid>
<link>581331</link>
<comments>
h.ttp://dutplanet.net/info.php?id=581331&spotinfo=1&infoid=274687
</comments>
<newznab:attr name="category" value="2040"/>
<newznab:attr name="size" value="904147968"/>
<enclosure url="h.ttp://dutplanet.net/connect/nzbdown.php?id=581331&api=*******" length="904147968" type="application/x-nzb"/>
</item>
The correct link to the nzb seems to be in the url part of the enclosure element. The link element only has an id.
Now if I compare this xml to for example one that comes from nzbplanet.net:
<item>
<title>Snowpiercer.2013.1080p.BluRay.Dts.x264-CYTSUNEE</title>
h.ttps://nzbplanet.net/details/d83276a5888e9d55c4ae70f34e77e67e
</guid>
<link>
h.ttps://nzbplanet.net/getnzb/d83276a5888e9d55c4ae70f34e77e67e.nzb&i=185622&r=****
</link>
<comments>
h.ttps://nzbplanet.net/details/d83276a5888e9d55c4ae70f34e77e67e#comments
</comments>
<pubDate>Sun, 24 Aug 2014 19:37:39 +0200</pubDate>
<description>Snowpiercer.2013.1080p.BluRay.Dts.x264-CYTSUNEE</description>
<enclosure url="h.ttps://nzbplanet.net/getnzb/d83276a5888e9d55c4ae70f34e77e67e.nzb&i=185622&r=***" length="14391398153" type="application/x-nzb"/>
<newznab:attr name="category" value="2000"/>
<newznab:attr name="size" value="14391398153"/>
<newznab:attr name="guid" value="d83276a5888e9d55c4ae70f34e77e67e"/>
</item>
Nzbplanet seems to add the link the the nzb in the link element as well.
I’m wondering if this problem is being caused by dutplanet sendin incorrect xml or sonarr is just parsing something incorrect.
BTW I changed http / https to h.ttp / h.ttps in this mail because the forum will only accept 2 links from new users.
