Sonarr, ACD & Rclone
Hey all.
I’m just wondering if anyone can shed some light on an issue I’m having.
Firstly Sonarr is installed on a Hetzner server. It downloads and renames to the server and then an rclone script runs via “connect” and there are no issues, Everything just works and rclone copies the files to ACD.
However occasionally I like to point all my shows to ACD just to scan and make sure all files are there.
Using the bulk option when adding the root of my TV Shows on Amazon it says the directory is not writeable by “my username”. So yeah a permissions issue or so I thought.
However strangely enough pointing the shows individually will happily work and scan the files… Just really heavy going with currently 80+ active shows…Just curious for any insight to what the issue may be? I don’t do Linux let alone Linux permissions so I’m using Quickbox.io
I’m gonna copy and paste this in the rclone section because I’m pretty sure its not a Sonarr issue, but it does still baffle me that the root TV shows folder is not writeable yet the actual Shows subfolders inside that root directory clearly are? Any thoughts would be appreciated.
